Since users usually keep their AC adapter connected while using their laptop, the battery is often in a state of high-power(98-100%) for extended length of time which causes a reduction in battery life.
In order to protect the battery, Battery Health Charging allows you to set your battery's maximum power of RSOC (Relative State Of Charge) which helps extend the battery's lifespan.
Information
When this app is activated, there are three modes to choose from, depending on your own requirements.
1. Full Capacity Mode:Default setting.
2. Balanced Mode
3. Maximum Lifespan Mode
Functions and settings
1.Ten minutes after your first OS login, the message"Battery power setting is in Full Capacity Mode now"will automatically pop up. Please click ‘X’ to close this message.
If you choose to keep the current mode, the message will pop up again after 90 days. When you switch to either of the two modes (Balanced Mode/ Maximum Lifespan Mode), this message won't pop up again until you change back to the default mode (Full Capacity Mode).
2. You can change the setting by clicking Set it up now in the pop-up message,then close the dialog window.
Move the mouse cursor over the Tray icon and right-click the Battery icon to select the mode you want to use. The current mode can be confirmed by the color shown in the Tray icon.
A. Full Capacity Mode(Yellow color): Battery is charged to its full capacity for longer use on battery power.
B. Balanced Mode(Blue color): Stops charging when power is above 80% and resumes charging when power is below 78%. This mode is recommended when using the Notebook on battery power during meetings or conferences.
C. Maximum Lifespan Mode(Green color): Stops charging when power is above 60% and resumes charging when power is below 58%. This mode is recommended when the Notebook is always powered by AC adapter.
