FAQBot
Community Manager
Community Manager
[Troubleshooting] WiFi signal is often disconnected
To provide you more detailed instruction, you can also click ASUS Youtube video link below to know more about Troubleshooting for Wi-Fi signal is often disconnected
https://youtu.be/FgU4d3Jd3O0
Situation
1. When WiFi devices cannot access to internet, please go to ASUS router web interface > network map to check whether the network map shows internet disconnected.
    When WiFi devices cannot access the Internet, is the wired device unable to access the Internet too?
    If Internet status shows disconnected or wired devices cannot access to internet, please refer to below FAQ for internet trouble shooting.
2. If ISP modem has WiFi function, try to connect WiFi devices to Internet Service Provider (ISP) modem WiFi to see if WiFi  device can access to internet through modem WiFi .
    If WiFi device can access to internet via Modem's WiFi, please login to ASUS router UI to see if router internet status shows disconnected. May refer to FAQ for details.
     If WiFi device cannot access to internet via Modem' WiFi,
         (1). Please contact your ISP for modem internet issue.
         (2). If Wired devices can access to internet via modem, may refer to below trouble shooting steps.
3. When you use a wireless router to connect to the Internet, you find that your wireless connection device is often disconnected.
    (E.g. use a phone, computer, etc. to connect router's WiFi SSID (2.4 GHz or 5 GHz) easy to disconnect)
    You can refer to the following steps for simple troubleshooting.
Introduction
1. Please make sure the firmware of the router is up to date
You can set up your ASUS router via Web GUI or ASUS Router app, check that your router firmware version has been updated to the latest version.
  • Enter the Web GUI(router setting page), go to [Network Map] > click the firmware Version.
  • Enter the ASUS Router app, go to [Settings] > [Firmware Upgrade] > [Check Firmware Version].
For the information of how to upgrade firmware,  please refer to the FAQ below
2. Set the channel bandwidth to default
Channel Bandwidth will affect your wireless speed performance and signal stability. In default, the ASUS router will adjust the channel bandwidth automatically.
  • Band 2.4 GHz : Default channel bandwidth [20/40 MHz]。
  • Band 5 GHz  / 5 GHz-1 /  5 GHz-2 : Default channel bandwidth  [20/40/80 MHz]。
  • Band 6 GHz  : Default channel bandwidth  [20/40/80/160/320 MHz]。
Note:
(1)  Some functions of wireless will be different due to firmware version.
(2) Currently, you can only adjust the channel bandwidth from the ASUS router settings page (Web GUI).
Go to [Wireless] > [General], you can set the channel bandwidth for different frequency bands ( 2.4 GHz / 5 GHz / 5 GHz -2/ 6 GHz ) respectively.
Interface 1: Supports routers with firmware later than 3.0.0.6.102_35404 (including)
Interface 2: Supports routers with firmware earlier than 3.0.0.6.102_35404
Please refer to [Wireless Router] How to improve wireless speed by setting Channel Bandwidth in Wireless Router to learn more.
3. Switch to a control channel with less interference
If your router uses the same channel as other nearby wireless devices, it may cause interference and slow speeds.
The wireless channel of the ASUS router is default to [Auto], you can switch to a control channel with less interference.
Note:
(1) Supported channels of 2.4 GHz, 5 GHz and 6 GHz WiFi differ according to each country’s local law and restrictions.
(2) Some functions of wireless will be different due to firmware version.
(3) Currently, you can only adjust the control channel from the ASUS router settings page (Web GUI).
Go to [Wireless] > [General], you can set the control channel for different frequency bands ( 2.4 GHz / 5 GHz / 5 GHz -2/ 6 GHz ) respectively.
(a). The following figure takes the band 2.4 GHz as an example, the default control channel is [Auto], and the current control channel is 2.
 Select a different control channel, and then click Apply to save.
(b). The following figure takes the band 5 GHz-1 as an example, the default control channel is [Auto], and the current control channel is 10.
 Please cancel [Auto select channel including DFS channels], and select a different control channel, and then click Apply to save.
 What is DFS channels? please refer to [Wireless Router] What is DFS (Dynamic Frequency Selection) and how does it work on ASUS router? to learn more.
(a). Band 2.4 GHz
(b). Band 5 GHz
(c). Band 5G-2Hz, cancel [Auto select channel including DFS channels].
4. Try to disable Smart Connect
You can set up your ASUS router via Web GUI or ASUS Router app.
Note: Some functions of wireless will be different due to firmware version.
Turn off Smart Connect: You can set different WiFi names and passwords for different WiFi bands.
(1) For example, if you want to add a new 2.4 GHz WiFi band, keep 2.4 GHz, unchecked other WiFi bands, and then click [Apply] to save the settings.
(2) As shown in the figure below, the WiFi network is in the 2.4 GHz WiFi band, that is, the Smart Connect is turned off.
Go to Wireless > General > Switch the button on [Enable Smart Connect] to off.
For the information of how to configure Smart Connect, please refer to [Wireless Router] How to configure the Smart Connect in ASUS Router?
5. Try to adjust the direction of the router's antennas
You can try adjusting the angle of the external antenna (e.g. 45 degrees, 90 degrees, etc.) to the optimal signal distance.
Below we take RT-AC88U for example, for other models, please refer to user manual.
To ensure the best wireless signal, set the four detachable antennas as below suggested image. Below we take RT-AC88U for example, for other models, please refer to user manual.
[Note] You can download the user manuals in the ASUS Download Center.
6. Adjust the placement of the router
It is recommended that the user can adjust the placement of the router, close to the wireless device client, and shorten the distance between the wireless router and the client, to avoid the distance of the signal transmission affecting the strength of the signal.
WiFi is distinguished into 2.4 GHz and 5 GHz, the 2.4G Hz signal transmission distance is farther than 5 GHz, but slower than 5 GHz, 5 GHz although the signal transmission distance is shorter, but the speed can be faster.
When your wireless device is often disconnected, you can first check that your wireless device is connected to WiFi (2.4 GHz or 5 GHz) and confirm the distance between the wireless device and the router when the WiFi is disconnected.
For the information,  please refer to the FAQ [Wireless Router] How to improve Wi-Fi Connection
7.Environmental interference
Make sure that no interference or barriers affect the wireless signal around the wireless router, and remove the interference and barriers whenever possible, or try to replace the location of the wireless router.
  • Interference: microwave ovens, refrigerator, wireless phones, power boxes... And so on, some home appliances will also produce interference with wireless channels.
  • Barriers: iron cabinets, iron doors, cement walls, closed cabinets, placed on the ground, behind the sofa. Some high-density building materials can also affect WiFi signal penetration, such as gypsum, planks, barbed wire, etc.
It is recommended that you place the router in the center of the environment where possible, in an open area, where there is less furniture, where there is no wall barrier, or on a wooden cabinet, on a tabletop.
8. Update the wireless device driver or firmware
Confirm that the wireless device driver or firmware you are using has also been updated to the latest version. Please contact your device manufacturer for any updates.
  • Wireless device: Such as Laptop, Smart Phone, USB WiFi Adapter, CONSOLE.
Mac device WiFi signal is often disconnected after roaming between AiMesh router and nodes, refer to this FAQ.
9. Restore the router to default settings
Follow the steps below to restore your router to its factory settings, or refer to the FAQ [Wireless Router] How to reset the router to factory default setting?
Note: After resetting the router, all the settings will be cleared and will need to be setup again.
(1) Please find the RESET button, following pictures take RT-AC68U as an example.
(Different models might have slight differences, please confirm the related information in the user manual if you have any concern.)
(2) Press the RESET button around 5~10 seconds, release the RESET button after the power LED light starts flashing.
In the meantime, all the LED indicators of the router should be off and it’s a normal phenomenon because the router is rebooting itself.
And wait until the Power LED indicator and WiFi LED indicators are on again, you could try to enter the GUI of the router again.
(3) Use the Quick Internet Setup (QIS) to setup your router again.
About how to use Quick Internet Setup (QIS) to setup your router, please refer to
If you try the above method can not solve, you could try Hard Factory Reset to fix the issue.
For more details could refer to [Wireless Router] When Standard Reset Isn’t Working: Hard Factory Reset - Models list
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
Version history
Last update:
‎10-07-2025 03:44 AM
Updated by:
