FAQBot
Community Manager
Community Manager
[Troubleshooting] How to fix AirPrint cannot print through wireless router?
In some cases, you can't print or the wireless printer won't connect to Wi-Fi. It may be a problem with the printer, mobile device, wireless router, etc.
Please refer to the instructions below.
Introduces
 1. Unable to connect to Wi-Fi
 2. Unable to print documents using AirPrint
 3. Check the Wi-Fi specifications of your Wi-Fi printer and wireless router
 4. Check the IP segment of the Wi-Fi printer and wireless router
 5. Try restarting the Wi-Fi printer and wireless router
 6. Try to update the Wi-Fi printer and wireless router system/firmware version to optimize device p...
 7. Try to reset the wireless router
 1. Unable to connect to Wi-Fi: Please check that your connection settings are correct.
    a. Check whether the Wi-Fi printer you are using supports AirPrint, and turn the printer on after confirming that it does.
        If your printer model name is not in the AirPrint list, it may not support AirPrint.
        For related information, please ask your wireless printer manufacturer and refer to Apple's official website for instructions. About AirPrint - Apple Support
   b. Network environment
       b-1 To set the wireless name and password of the wireless router, please refer to the FAQ [Wireless Router] How to modify Wireless(Wi-Fi) Name and Password in ASUS Router
       b-2 iOS mobile device to use the printer, such as iPhone.
       b-3 Connect the Wi-Fi printer and iPhone to the wireless network (Wi-Fi) of the same wireless router.
   c. Note
       The iPhone and the Wi-Fi printer need to be connected to the same wireless network (Wi-Fi) source, and the Wi-Fi printer should be placed close to the wireless router to shorten the distance between the Wi-Fi printer and the wireless router.
       Please refer to the FAQ below:
       Please avoid using the guest network. The guest network function in the ASUS wireless router is an independent wireless network environment. If the Wi-Fi printer is connected to the wireless network (Wi-Fi) established by the guest network, it may this will cause the mobile device that wants to use the printer to not be able to find the printer.
       Please refer to the FAQ [Wireless Router] How to set up Guest Network(WebGUI/App)
 2. Unable to print documents using AirPrint: Please check that your connection settings are correct.
     a. Please follow the iPhone product description settings, open the application you want to print the document, tap the [Share] > [Print], and select the printer you want to use in the printing function.
     b. If your printer is not powered on or in sleep mode, it may be offline. Please try to start or wake up the printer to a working state.
         Note: Before printing with a printer, please check that the paper has been loaded into the printer and that there is enough ink or toner, and then start printing after confirming that there is enough.
                  Different printer manufacturers provide different processing methods. For related instructions, please refer to the applications and troubleshooting methods provided by the printer manufacturers.
     c. Try to use a password-protected wireless network (Wi-Fi), please reconnect to a password-protected wireless network (Wi-Fi).
     d. When your Wi-Fi printer cannot connect to a wireless network (Wi-Fi), it is recommended to try to use other devices (laptops or other phones) to connect to the same wireless (Wi-Fi) network to confirm whether the same situation exists.
         If only the Wi-Fi printer cannot connect to the wireless network (Wi-Fi), it is recommended to contact your Wi-Fi printer manufacturer for help.
          Different printer manufacturers provide different troubleshooting instructions. Please refer to the troubleshooting instructions provided by the printer manufacturer.
3. Check the Wi-Fi specifications of your Wi-Fi printer and wireless router: Check whether the Wi-Fi printer and wireless router support 2.4GHz or 5GHz, or both.
    It is recommended to try connecting the printer to Wi-Fi of different frequency bands (2.4GHz / 5GHz) for cross-testing to confirm whether the problem can be solved.
 4. Check the IP segment of the Wi-Fi printer and wireless router:
     By default, ASUS routers will randomly assign a set of virtual IPs to devices. However, if your Wi-Fi printer has a fixed IP address by default, it is recommended to change it to the same IP segment.
     For example, the IP address of the Wi-Fi printer is 192.168.0.20 , and the IP network segment of the ASUS router must also be 192.168.0.1 ( the " 0" here is the IP network segment)
5. Try restarting the Wi-Fi printer and wireless router: When you have problems with your Wi-Fi printer and wireless router, restarting them can fix the problem.
    Try restarting your Wi-Fi printer and wireless router to see if this improves. Please refer to the FAQ below:
     Note: Restarting the router will not affect any existing settings of the wireless router. Instead, it can release some data temporary storage space (RAM) to improve system performance and make the wireless router run more smoothly.
6. Try to update the Wi-Fi printer and wireless router system/firmware version to optimize device performance: Update your firmware version regularly to ensure that your device remains in optimal condition.
    Please refer to the link below or contact your device manufacturer for information on how to update system firmware/software.
      Note: After updating the firmware of the ASUS router, it is recommended to reset the router to the factory default. After the router is set up, reconnect the phone to the router's wireless (Wi-Fi) network.
[Wireless Router] How to reset the router to factory default setting
[Wireless Router] How to set up ASUS Wi-Fi router via ASUS Router App? (QIS, Quick Internet Setup)
7. If you need to try to reset the router, you can refer to the following two methods:
    a. Try to reset the router - standard restore (Reset): Please find the RESET button on the router shell, press the RESET button for about 5-10 seconds until the router's power LED light starts flashing, the reset is completed.
        Please refer to FAQ https://www.asus.com/support/FAQ/1000925#Way2
    b. Try to reset the router - Forced factory reset (Hard Factory Reset): If the standard restore (Reset) cannot solve the problem, you can use another method to force the factory reset (Hard Factory Reset).
        Please refer to FAQ [Wireless Router] When Standard Reset Isn’t Working: Hard Factory Reset - Models list
Version history
Last update:
‎10-07-2025 05:28 AM
Updated by:
