ROG OMNI Figure Product Description and Handling Procedure
ROG OMNI OG Package contains:
ROG OMNI Figure OG/ Mask/ Spray Can/ Nano Wrench/ Skateboard
- Ears: The ears have a 360-degree rotatable design, allows for flip-open/close ear poses.
- Mask: The mask can be lightly attached to the head. To remove the mask, please gently pressure at the click point.
- Head: The head can rotate to a full 360 degrees, allows for tilting up/down and turning motions.
- Shoulder/Elbow: The shoulder joint of the arms can rotate 180 degrees, and the elbow can rotate 45 degrees forward or backward.
- Hands: The finger joint on each hand can form a fist and allow the figure to hold its accessories.
- Thighs: The hip joints can rotate approximately 30 degrees forward or backward.
- Lower legs: the knee joints can rotate 90 degrees forward or backward.
- Tail: The tail is made of soft rubber and can rotate 360 degrees.
- Skateboard: The skateboard is functional and can roll. It can be attached to figure’s feet to make a skating pose.
ROG OMNI WHITE Package contains:
ROG OMNI Figure WHITE/ Mask/ Toolbox/ Nano ROG Ally/ Skateboard
- Toolbox: The toolbox features an open-and-close design and can store accessory-nano ROG Ally.
[Product policy & handling procedure]
- The Figure does not come with a warranty.
- For new product defects, you may request an exchange from the original purchased place within seven days of receiving the product, with proof of purchase.
When purchasing from physical stores, please ensure the packaging is intact and that the contents match the labeled information before making your purchase. - Damage/malfunctions caused by improper use or disassembly of the product are not covered under the exchange policy.
- Toy/Figure products are mass-produced in factories. Minor paint imperfections, slight unevenness in the paint finish, loose or tight joints, etc., are considered normal and are not considered defects.
