FAQ
Knowledge Base Articles
[Gaming NB/DT] Armoury Crate Application Introduction
[Gaming NB/DT] Armoury Crate Application Introduction Armoury Crate Introduction (Ver5.0)Armoury Crate Introduction (Ver4.0)Armoury Crate Mobile Version Introduction (Android/ iOS)Armoury Crate - Installation SOPAniMe Matrix™ Display - IntroductionKe...
FAQBot by Community Manager
  • 41 Views
  • 0 comments
  • 0 kudos
MyASUS Frequently Asked Question (FAQ)
MyASUS Frequently Asked Question (FAQ)Table of Contents [Phone] MyASUS App - Introduction  [Motherboard] MyASUS introduction  [Notebook] MyASUS-Unable to reset GPU mode to default value  [Notebook] MyASUS - Introduction  [Notebook] MyASUS- Settings  ...
  • 49 Views
  • 0 comments
  • 0 kudos
ASUS Router Plug-n-Share Disks Compatibility List
ASUS Router Plug-n-Share Disks Compatibility List* OS encrypted hard drives are not supported.   Wireless RouterModelFirmware versionMaximumPartitionNumberDisk Format & Maximum Partition Size:File Size:FAT32EXT2EXT3EXT4NTFS   (Read Only)NTFS   (Write...
  • 18 Views
  • 0 comments
  • 0 kudos
[Desktop] Troubleshooting - No Sound After Installing Internal Speakers
[Desktop] Troubleshooting - No Sound After Installing Internal SpeakersApplicable Products: ASUS ExpertCenter D5 Mini Tower (D501MER)、ASUS ExpertCenter D5 SFF (D501SER)、ASUS ExpertCenter D7 Mini Tower (D701MER)、ASUS ExpertCenter D7 SFF (D701SER) If y...
  • 13 Views
  • 0 comments
  • 0 kudos
[AIO CPU Liquid Cooler]ASUS Infohub Introduction
[AIO CPU Liquid Cooler]ASUS Infohub IntroductionWith the ASUS Infohub application, you can intuitively control the all-in-one liquid cooler’s LCD display. Add custom content, monitor system hardware information, set the clock, and choose from a varie...
  • 18 Views
  • 0 comments
  • 0 kudos
internal test
internal test <meta charset="UTF-8" /> 產品型號篩選 產品: --請選擇產品-- 型號: --請選擇型號-- 產品型號韌體版本分割磁區最大數量FAT32EXT2EXT3EXT4NTFS (Read Only)NTFS (Write Only)FAT16HFS+exFATFAT32.1EXT2.1EXT3.1NTFS (Read Only).1NTFS...
  • 8 Views
  • 0 comments
  • 0 kudos
[Motherboard] Introduction to Fan Xpert 4 in Armoury Crate
[Motherboard] Introduction to Fan Xpert 4 in Armoury CrateFan Xpert 4 is a tool embedded within the Armoury Crate software, used to control fans connected to the motherboard. It can detect various fans on the motherboard and offers a variety of adjus...
  • 25 Views
  • 0 comments
  • 0 kudos
[AIOT] Flash OS Image by Windows for PE1000N
[AIOT] Flash OS Image by Windows for PE1000N1. Preparing your Environment1. Update Windows version to build 19041 or higher2. Open Windows PowerShell as administrator mode3. Type the command below in PowerShell to enable WSL and Virtual Machine1.dism...
  • 21 Views
  • 0 comments
  • 0 kudos
[AIOT] Flash OS Image by Ubuntu for PE1000N
[AIOT] Flash OS Image by Ubuntu for PE1000N1. Recovery Mode1. System Requirement• Linux Host Computer (x86 Ubuntu 18.04 and above)• Micro USB cable2. Enter Force Recovery ModeFor PE1000N Box, the Flash Port is number ❸, and the Force Recovery Button ...
  • 28 Views
  • 0 comments
  • 0 kudos
[AIOT] Upgrade to Jetpack 6.1 for PE1100N
[AIOT] Upgrade to Jetpack 6.1 for PE1100NPlease make sure your OS is Jetpack 6.0$ cat /etc/nv_tegra_release  Add the R36.4/JP 6.1$ echo "deb https://repo.download.nvidia.com/jetson/common r36.4 main" | sudo tee -a /etc/apt/sources.list.d/nvidia-l4t-a...
  • 23 Views
  • 0 comments
  • 0 kudos
[AIOT] OS Version Information for PE1100N
[AIOT] OS Version Information for PE1100NPlease refer to the table below for recommended OS versions and NVIDIA SDK versions for each image versionPE1100N official release versionL4TUbuntuJetPackCUDADeepStream SDKcuDNNTensorRTV1.0.035.3.120.045.1.111...
  • 37 Views
  • 0 comments
  • 0 kudos
[AIOT] Console Port Set Up for PE1100N
[AIOT] Console Port Set Up for PE1100NPE1100N console port connect to PC - USB to UART Bridge.When PE1100N console port is connected to a PC, it is possible that a USB to UART Bridge exclamation mark may appear in Device Manager.The baud rate is 1152...
  • 25 Views
  • 0 comments
  • 0 kudos
[AIOT] Switch DIO Sop for PE1100N
[AIOT] Switch DIO Sop for PE1100NOpen Terminal on the desktopType below command to switch DIOSet one DO Value: sudo dio_out #DO_Num # Value Get one DI Value: sudo dio_in #DO_Num Get all DO Value: sudo dio_out Get all DI Value: sudo dio_in
  • 21 Views
  • 0 comments
  • 0 kudos
[AIOT] Check SIM Card Status for PE1100N
[AIOT] Check SIM Card Status for PE1100N1. Open Terminal on the desktop 2. Type command ‘sudo PE1100N-config’, if it asks for a password, enter the password set by yourself. Press Enter. 3. Select Ok   4. Select 7. Configuration and press Enter 5. Ch...
  • 23 Views
  • 0 comments
  • 0 kudos
[AIOT] LTE Setting Information for PE1100N
[AIOT] LTE Setting Information for PE1100NNOTE : Please insert the SIM card and power on the device.1. Click to open the settings bar at the top right side of the desktop. 2. Click Mobile Broadband Settings.  3. Switch on the Mobile Broadband to enab...
  • 42 Views
  • 0 comments
  • 0 kudos
[AIOT] Flash OS Image for PE1100N
[AIOT] Flash OS Image for PE1100NPE1100N only support flash image via Ubuntu and doesn't support flash image via Windows.1. Recovery Mode1. System Requirement• Linux Host Computer (x86 Ubuntu 18.04 and above)• Micro USB cable2. Enter Force Recovery M...
  • 27 Views
  • 0 comments
  • 0 kudos
[AIOT] Console Debug Information for PV100A
[AIOT] Console Debug Information for PV100AHow to use Android Debug Bridge (adb)1. Prepare an USB Type-C to Type-A cable.2. Connect your device with USB: Connect cable Type-C side to PV100A and Type-A side to PC.You can verify that your device is con...
  • 40 Views
  • 0 comments
  • 0 kudos
[AIOT] Power Ignition Control for PV100A
[AIOT] Power Ignition Control for PV100ADefault valueItemsDefault delay time (Seconds)Ignition on delay0Ignition off delay0Hard off delay180        Note:When the ignition off delay ends, and the system has not shut down normally for more than 180 sec...
  • 22 Views
  • 0 comments
  • 0 kudos
Top Contributors
