on 10-08-2024 12:38 AM - edited 3 hours ago by ZenBot
[PN53/PN53-B] Power LED pattern
The power indicator LED on the PN53/PN53-B models has two colors: white and amber.
Under normal startup conditions, the LED lights function as follows:
If the device fails to start, the LED will display one of the following conditions:
After pressing the power button, the indicator light remains white.
During the startup process, the indicator light flashes amber repeatedly.
If you encounter any of the above issues, please check for any loose connections with the respective components or contact ASUS support.
