FAQBot
Community Manager
Community Manager
[Phone] What do the LED light indicator colors mean?
Note: Please enable the LED indicator  : Go to Settings Display >enable LED indicator . (Example : Android 9)
ItemCategoryDescription
LED Indicator-1Device is connected to a chargerWhen device is ON or OFF and connected to a charger, the LED indicator will light orange.
LED Indicator-2Device is connected to a charger and charging completed When device is ON and connected to a charger, the LED indicator will light green after the battery is fully charged.
LED Indicator-3Device is connected to a charger when battery exhaustedWhen device is OFF with the battery exhausted (too low to boot up the device) and connected to a charger, the LED indicator will light red indicating that the system is at extremely low battery status. (the LED indicator of ZC520KL/ZC554KL will flash red if the battery is completely discharged)
LED Indicator-4Low batteryWhen device is ON with battery level lower than 15% and not connected to a charger, the LED indicator shall flash red every 4 seconds.
LED Indicator-5NotificationsWhen device is ON or in Sleep mode, the LED indicator will flash green every 2 seconds to notify users when there are missed calls, unread messages, or incoming mail notifications.
LED Indicator-6Timer reset policyAccording to LED Indicator-5, the system will reset the timer when users clear, remove or tap to open the specified notifications of missed calls, unread messages, or incoming mails.
LED Indicator-7Priority of eventsThe system prioritizes the different statuses as below:
1.PadFone station connection status (LED Indicator-8)
2. Power connection status (LED Indicator-1, LED Indicator-2, LED Indicator-3, LED Indicator-4)
3. Applications notification (LED Indicator-5, LED Indicator-6)
LED Indicator-8PadFone station connection statusWhen users dock the device on a PadFone station and have a connection error, the LED indicator on the PadFone station shall light red to notify users, regardless if the device is connected to a charger or not.
LED Indicator-9LED indicator light durationThe LED indicator light duration is 25 ms.
Version history
Last update:
Sunday
Updated by:
Contributors
