FAQBot
Community Manager
Community Manager
[Phone] Troubleshooting - Power percentage display is abnormal
Applicable situations: The battery display is incorrect.
Please follow the below steps for troubleshooting :
1. Battery display styles: Enter Settings > Battery > Visual settings > Battery display styles > Select Icon and percentage.
2. Tap and hold the power button to power off your device and reboot.
3. Update firmware to the latest version:Enter Settings > System > System updatesCheck Update.
4. Access to Safe Mode ( long press power key > Tap and hold Power Off > Tap OK:If your phone / Tablet works well in Safe Mode ,malfunction may be caused by some 3rd party apps . Please reboot your device and check again if it works well.
5. Backup your data and perform factory data reset.
    *Note:Once RESET has been executed and performed, all the data, apps, settings and personal information will be deleted after initialization.
If the above steps can't solve your issue, please contact your local ASUS Customer Center for technical support.
Version history
Last update:
2 weeks ago
Updated by:
Contributors
