on
10-26-2023
06:11 PM
- edited on
10-13-2024
12:59 AM
by
ZenBot
[Phone] ROG Phone-How to partial apply the icon, wallpaper or sound effect from different themes?
[Phone] ROG Phone-How can I preview sounds of a theme?
[Phone] ROG Phone-How do I use specific parts of a theme?
Long press Launcher > Tap Themes > Select one theme and tap the drop-down menu icon next to Sound previews. Tap the icon next to the sound effect you want to hear in the expanded menu, and the sound will play.
Long press Launcher > Tap Themes > Select one theme and tap Download. After the download is complete, tap Customize. In the list, all the items of partial apply will be pre-checked. If you do not want to apply a specific item, just uncheck them and tap Apply.
