[Phone] ROG Phone - How do I adjust swipe setting when AirTriggers are triggered?
To enable this feature, launch Armoury Crate.
Tap Console > AirTriggers Preferences and touch settings.
Tap Swipe setting.
Set trigger speed for the left and right fingers to slide in the touch area. Slide between low and high to set the trigger speed. Tap Apply when finished.
Note: The higher the trigger speed is set, the faster the finger needs to slide to trigger the swipe function.
