on
10-26-2023
06:12 PM
- edited
Saturday
by
ZenBot
[Phone] How to use Wireless Charging
Wireless Charging
Please confirm that your ASUS phone supports wireless charging.
We recommend using a wireless charging pad that complies with the Qi standard. Qi is a universal wireless charging standard established by the Wireless Power Consortium (WPC). Check the Qi-certified charger list before purchasing.
*Features and performance of Qi certified chargers may vary. If you have any questions, please contact the manufacturer.
1. Connect the charging pad to a power source and place it on a flat surface.
2. With the phone screen facing up, align the central area of the phone with the wireless charging pad.
Actual charging speed may vary based on environmental conditions, phone status, and accessories. To ensure wireless charging efficiency, we recommend using the official ASUS charger or a charger recommended by your charging pad manufacturer. If you use both wired and wireless charging simultaneously, wired charging will take priority.
Notes:
Charging Interference: Placing any objects between the phone and the charging pad may cause intermittent charging or suboptimal performance. Please remove such items. If you place magnetic materials (e.g., metal objects) , credit cards, or items with RFID chips between the phone and the charging pad, it may damage these items or affect charging efficiency. If your protective case contains any of the mentioned items, please remove it before charging.
Charging Temperature Protection: During charging, your phone’s temperature may rise. To protect battery health and life, if the battery temperature becomes too high, the phone may temporarily stop charging and resume once the temperature decreases. Keep your phone in a cool and well-ventilated environment.
