FAQBot
Community Manager
Community Manager
[Phone] How to Set Up Auto-start Management
Auto-start management is a reliable and effective tool that helps you control which apps can start automatically in the background. This can improve system performance and extend battery life. If you notice your phone slowing down, it might be because some apps are auto-starting in the background, consuming too much memory and battery power. By using the auto-start management feature, you can prevent unnecessary apps from auto-starting, thus freeing up memory and extending battery life.
1. Open the Settings app on your phone.
2. Go to Battery > Auto-start Manager.
3. Select the apps you want to manage and set them to either deny or allow to auto-start when device boots.
Tips:
⦁ Settings may vary depending on your phone model.
⦁ Deny auto-start may delay some apps notification. You may allow auto-start again if it happens.
⦁ Allow auto-start may consume memory. To save memory, please remain denying auto-start.
Version history
Last update:
‎10-07-2025 06:24 PM
Updated by:
