on 03-01-2023 11:22 PM - edited 2 weeks ago
[Phone] How to set System modes(Battery modes)/Low battery power-saving(Low battery alert)/Schedule power-saving?
How to set System modes(Battery modes):
In system mode, you can not only configure various modes as needed but also set parameters related to mobile networks, Wi-Fi, screen sleep time, screen refresh rate, and system color schemes within each mode.
Swipe down from the top of the screen to access Quick Settings > tap the Settings icon > Battery > System modes.
Use the Dynamic mode by default, and you can adjust the mode as needed.
How to set Low battery power-saving(Low battery alert):
You can customize Low battery power-saving at the battery level based on your requirement.
Swipe down from the top of the screen to access Quick Settings > tap the Settings icon > Battery > Low battery power-saving
*If you have switched on Enabled power-saving mode automatically, low battery notifications suggesting entering power-saving mode will not be displayed.
How to set Schedule power-saving:
You can set your device to automatically enter power-saving mode at a specified time, according to your needs.
Swipe down from the top of the screen to access Quick Settings > tap the Settings icon > Battery > Switch on Schedule power-saving
After switching on, you can tap the Scheduled Power Saving and adjust the time period for power-saving.
