on 03-01-2023 11:22 PM - edited Saturday
[Phone] How to set Battery care (Steady charging (Slow charging)/Scheduled charging/Charging limit)
How to set Steady charging(Slow charging):
For better battery health protection, you can choose to charge the battery at a lower rate to prevent the battery aging.
Swipe down from the top of the screen to access Quick Settings > Tap the Settings icon > Battery > Battery care > Switch on the Steady charging
After switch on and connecting to power, you can tap the Steady charge to adjust the upper limit of charging power for Steady charging.
*The charging power limit may vary based on the adapter wattage.
How to set Scheduled charging:
Leaving the battery fully charged for a long time (e.g. overnight charging) may reduce the battery's capacity. You can schedule charging to dynamically adjust the charging power during specific periods, reducing the time when the battery remains fully charged without being used.
Swipe down from the top of the screen to access Quick Settings > Tap the Settings icon > Battery > Battery care > Switch on the Scheduled charging
After switching on, you can tap the Scheduled charging and set a time period for scheduled charging or switch on the Auto end time based on your alarm. You can also automatically activate Do not disturb or Airplane mode in the sleep well settings to avoid interference from your phone while it's charging during the scheduled time.
How to set Charging limit:
Leaving the battery fully charged for a long time (e.g. overnight charging) may reduce the battery's capacity. To prevent battery from aging, you can set up the Charging limit at 80% or 90%.
Swipe down from the top of the screen to access Quick Settings > Tap the Settings icon > Battery > Battery care > Set the Charging limit ( ranges from 80% to 100%)
