FAQBot
Community Manager
Community Manager
[Phone] How to Fix Volume Button Not Working
Please follow these steps for troubleshooting:
1. If you are using a phone case, remove it to ensure it is not blocking the volume buttons.
2. Check the volume buttons for any debris or damage.
3. Restart your phone: Press and hold the power button > Tap Restart.
4. Update the system software to the latest version: Go to Settings > System > System update, and tap Check Update.
5. It could be caused by an app. Try uninstalling any recently installed apps.
   You can enter Safe Mode to disable third-party apps and see if they are causing the issue:
    ● Enter Safe Mode: Press and hold the power button > Press and hold the Power off option > Tap OK.
    ● Exit Safe Mode: Restart your phone to exit Safe Mode.
6. Reset all settings: This will not delete your personal data, but will reset settings like Wi-Fi, Bluetooth, and app preferences.
    6-1. Open the Settings app.
    6-2. Tap System > Reset options > Reset all settings > Reset all settings.
7. If the above methods do not work, consider backing up your data and performing a factory reset.
    Note: Performing a factory reset will erase all your apps, settings, and personal information, returning the phone to its initial state. Make sure to back up your data beforehand.
*If your device continues to malfunction after following these steps, take it to an authorized service center or contact customer support.
Version history
Last update:
Sunday
Updated by:
