FAQBot
Community Manager
Community Manager
[Phone] How to fix the LED Indicator problems
If your ASUS phone's LED indicator is malfunctioning, you can try the following steps to troubleshoot the issue:
1. Check Settings: Check that the LED indicator is enabled in the system settings. Open Settings -> Display -> Indicator Light, and check if the relevant functions are enabled.
2. Reboot the Device: Try rebooting your phone. Sometimes a simple restart can resolve some temporary issues.
3. Update Software: Ensure that your phone's system software is updated to the latest version.
4. Use Safe Mode: Enter Safe Mode to check if any third-party applications are causing the problem. Press and hold the power button, then press and hold the "Power Off" option, and select to enter Safe Mode. Once in Safe Mode, check if the LED indicator is functioning properly. If it works fine, it might be an issue caused by a third-party application.
5. Contact ASUS Customer Service: If the above methods do not resolve the issue, it is recommended to contact ASUS Customer Service or visit the nearest ASUS Service Center for further assistance.
Version history
Last update:
Sunday
Updated by:
