on
12-07-2024
09:01 AM
- edited
Saturday
by
ZenBot
[Phone] How to fix the AniMe Vision Back Cover Display Issues
If your ASUS ROG Phone's AniMe Vision is malfunctioning, you can try the following steps to troubleshoot the issue:
1.Check Settings: Check that the AniMe Vision is enabled in the system settings. Open the Armory Crate app > Go to Console > Enable AniMe Vision > Click on More Settings. In the scenario lighting section, enable the scenarios you want.
2.Update Software: Ensure that your ROG Phone system software is updated to the latest version.
3.Reboot the Device: Try rebooting your phone. Sometimes a simple reboot can resolve some temporary issues.
4.Use Safe Mode: Enter Safe Mode to check if any third-party applications are causing the problem. Press and hold the power button, then press and hold the "Power Off" option, and select to enter Safe Mode. Once in Safe Mode, check if AniMe Vision is functioning properly. If it works fine, it might be an issue caused by a third-party application.
5.Restore Factory Settings: If the above methods do not resolve the issue, you can try backing up your data and restoring factory settings. Note that this will delete all data and settings, so make sure you back up all important data. Go to Settings -> System -> Reset Options -> Factory Data Reset.
6.Contact ASUS Customer Service: If the above methods do not solve the problem, it is recommended to contact ASUS Customer Service or visit the nearest ASUS Service Center for further assistance. They can perform more in-depth diagnostics and repairs.
By following these steps, you should be able to identify and resolve issues with the AniMe Vision on your ASUS ROG Phone.
