on
12-07-2024
09:01 AM
- edited on
10-07-2025
06:26 PM
by
ZenBot
[Phone] How to fix AirTriggers problems
If the AirTriggers function is malfunctioning, you can try the following steps to troubleshoot the issue:
1. Check Settings: Check that the AirTriggers function is enabled in the system settings. Open Settings -> Advanced Settings -> AirTriggers, and check if it is enabled and properly configured.
2. Update System Software: Ensure that your ROG Phone system software is updated to the latest version. Software updates may include fixes and improvements for the AirTriggers function.
3. Clean the Phone Surface: Ensure that the touch-sensitive areas on the sides of the phone are free of dust, grease, or other dirt. Use a clean, soft cloth to gently wipe the areas, ensuring the area is clean.
4. Reboot the Device: Try rebooting your phone. Sometimes a simple reboot can resolve many temporary issues.
5. Contact ASUS Customer Service: If the above methods do not resolve the issue, it is recommended to contact ASUS Customer Service or visit the nearest ASUS Service Center for further assistance.
