on
12-07-2024
09:01 AM
- edited on
10-07-2025
06:26 PM
by
ZenBot
[Phone] How to Fix Abnormal Vibration Function
If your ASUS phone's vibration function is abnormal, you can try the following steps to troubleshoot the possible issue:
1. Restart the phone:
Sometimes a simple restart can resolve many temporary issues. Press and hold the power button and select restart.
2. Check settings:
Go to "Settings" > "Sound & vibration" > "Vibration & haptic," and ensure the function is turned on.
Check if "Do Not Disturb" mode is enabled, as this might affect the vibration function.
3. Update system software:
Ensure your phone is running the latest version of the operating system. Go to "Settings" > "System" > "System update" and check for available updates.
4. Enter safe mode:
Sometimes third-party applications may cause conflicts. Entering safe mode can help you determine if an app is causing the issue. Turn off the phone, then press and hold the power button until the ASUS logo appears, and then hold the volume down button until you enter safe mode.
5. Reset all settings:
If the above methods do not work, you can try resetting all settings. Go to "Settings" > "System" > "Reset options" > "Reset all settings." This will not delete your personal data but will revert all settings to default.
6. Hardware check:
If none of the above steps solve the problem, it might be a hardware failure. It is recommended to contact ASUS customer service or take the phone to an authorized service center for inspection and repair.
