FAQBot
With ZenUI File Manager, it's easier to transfer your photos/data from mobile to PC without any cable or adapter. All you need is Wi-Fi to move files between mobile and PC wirelessly.
And you don't need to use your mobile for temporary file backup or storage anymore with a USB cable.
To use this feature, start with enabling Wi-Fi and opening your Internet browser on your PC.
On your mobile, launch File Manager then tap PC file transfer > Start.
Input the address that appears on your mobile screen to your PC’s browser then press Enter to start connecting both devices.
When both devices are connected, your PC browser will display the same File Manager screen you’d see on your mobile.
Click any file you want to transfer or right-click a folder to transfer all of its contents to your PC. You can also upload files from PC to mobile using this feature.
From mobile to PC:
From PC to mobile:
Experience the convenience of quick file transfers between your mobile and PC.
Download the latest version of File Manager from ASUS official site to enjoy all of its handy file management features.
Version history
Last update:
‎10-14-2019 12:00 AM
Updated by:
