on 01-29-2024 07:13 PM - edited on 03-10-2024 12:08 AM by ZenBot
[NUC] Where Can I Check If an NUC Has Integrated Wireless LAN?
Resolution
3. Choose the NUC product you would like to check if it has integrated wireless LAN.
4. After selecting the NUC product you chose, e.g:
5. choose the NUC that you have and click it to view the product Tech Specs. e.g:
6. From the product Tech Specifications of the NUC, you will see under the Wireless Included section that there's an Wireless Adapter listed if it has an integrated wireless adapter.
Note | For more information, contact Asus Support. |
