FAQBot
Community Manager
Community Manager
[NUC] What Are the Power Supply Specifications for the NUC Kit NUC8i[x]BEK?
Resolution
 NUC Kits with boards NUC8i3BE/NUC8i5BE/NUC8i7BE have the following power supply requirements and specifications:
  • External Power Supply – the board can be powered through a 12-19 V DC connector on the back panel.
  • The back panel DC connector is compatible with a 5.5 mm/OD (outer diameter) and 2.5 mm/ID (inner diameter) plug, where the inner contact is +12-19 (±10%) V DC and the shell is GND. The maximum current rating is 10 A.).
  • The Power Sensing Circuit has also been designed for use with 90 W AC-DC adapters.
Version history
Last update:
‎01-29-2024 06:57 PM
Updated by:
Contributors
