FAQBot
Community Manager
Community Manager
[NUC] Using PowerShell or WMIC with ​ NUC
Windows tools such as Powershell and WMIC can be used to get SMBIOS information from an NUC without having to enter the BIOS Setup.
Visual BIOS
SMBIOS sectionDisplays:
System Information
Information about the entire NUC unit, including:
  • Manufacturer
  • Product name
  • Version
  • Serial number
Board Information
Information about the motherboard inside the NUC, including:
  • Manufacturer
  • Product name
  • Version
  • Serial number
BIOS Information
Information about the BIOS, including
  • BIOS version
  • BIOS release date
NoteThe PowerShell and WMI commands listed below might not work with legacy NUCs and older BIOS versions. In these instances, the command will return characters like ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ or nothing at all.
Using PowerShell
Open Windows PowerShell:
  1. Press the Windows key.
  2. Type PowerShell and select Windows PowerShell.
Windows Powershell
To get this informationEnter this Powershell command
General System InformationGet-ComputerInfo | Format-List *
System > ManufacturerGet-WmiObject Win32_ComputerSystem Manufacturer
System > Product nameGet-WmiObject Win32_ComputerSystem Model
System > VersionGet-ItemProperty "HKLM:\HARDWARE\Description\System\BIOS" -Name SystemVersion
System > Serial numberGet-WmiObject Win32_BIOS SerialNumber
Board > ManufacturerGet-WmiObject Win32_BaseBoard Manufacturer
Board > Product nameGet-WmiObject Win32_BaseBoard Product
Board > Version (SA#)Get-WmiObject Win32_BaseBoard Version
Board > Serial numberGet-WmiObject Win32_BaseBoard SerialNumber
BIOS versionGet-WmiObject Win32_BIOS SMBIOSBIOSVersion
BIOS release dateGet-ItemProperty "HKLM:\HARDWARE\Description\System\BIOS" -Name BIOSReleaseDate
Using Command Prompt
Open a command prompt:
  2. Type cmd.
  3. Select Command Prompt.
To get this informationEnter this WMI command
System > Manufacturerwmic computersystem get manufacturer
System > Product nameNot available with WMIC
System > VersionNot available with WMIC
System > Serial numberwmic bios get serialnumber Note: this command doesn't return valid results on some NUCs.
Board > Manufacturerwmic baseboard get manufacturer
Board > Product namewmic baseboard get product
Board > Version (AA#)wmic baseboard get version
Board > Serial numberwmic baseboard get serialnumber
BIOS versionwmic bios get smbiosbiosversion
BIOS release datewmic bios get releasedate
You can get multiple results with one WMIC command, such as:
wmic baseboard get manufacturer,product,serialnumber,version
To view all available WMI command line switches, enter:
  • wmic computersystem get /?
  • wmic baseboard get /?
  • wmic bios get /?
Related topics
Windows Management Instrumentation (WMI)
Connecting to WMI Remotely with PowerShell
Version history
Last update:
Sunday
Updated by:
