on
01-29-2024
06:18 PM
- edited on
10-07-2025
04:09 AM
by
ZenBot
[NUC] Troubleshooting for System Hangs, Unexpected Shut Down, or Blue Screens (BSOD) on NUC Devices
Resolution
Troubleshooting recommendations:
| Check the power adapter | Verify that the power adapter works. Test with a different power adapter if one is available. If a different adapter works, contact Customer Support. |
| Check memory modules |
| Check the drive |
| Check for thermal issues | Check if the NUC shows signs of overheating. |
| Check the Network Boot setting in BIOS | If Network Boot is enabled in BIOS, random restarts or blue screen errors can occur.
| Update BIOS, drivers, and firmware | Download and install all the latest BIOS, drivers, and firmware. |
| BIOS recovery | Try a BIOS Recovery. |
| For issues during gameplay | If playing games, check for a corrupted configuration file for the game. |
| Additional steps | See No Boot or No Power Issues on NUC Products for more troubleshooting options |
If issue persists, contact Customer Support to discuss the steps you tried and for further troubleshooting.
