on
01-29-2024
06:55 PM
- edited on
10-07-2025
05:09 AM
by
ZenBot
[NUC] Troubleshooting AV Receiver Issues on NUC
If you see issues when your NUC is connected to an AV receiver, refer to the table below for troubleshooting tips and useful information.
| Notes |
| What are you seeing? | How to fix it. |
| Surround sound isn't working. | This issue can happen if the HDMI firmware on the NUC is out of date. See HDMI 2.0 Firmware update instructions. |
| No display when AV receiver is connected between the NUC and the TV. | This issue can happen if the receiver you're using doesn't support the same High-bandwidth Digital Content Protection (HDCP) version as is supported on the NUC. For example, if the receiver supports HDCP 1.4, but the NUC supports HDCP 2.2, you might not see a display. In this case, the older AV receiver won't be compatible with the NUC. |
| Related topic |
| Home Theater PC Setup Example |
