9 hours ago - edited 8 hours ago by ZenBot
[NUC] Troubleshooting Audio Issues on NUC
If you experience audio related issues with your NUC, we recommend you first try the following:
Note | Some models of NUCs do not have a 3.5mm audio jack (e.g NUC10i5FNHN). |
What is happening? | See article |
Can't get audio output from TV, Receiver, or monitor. | NUC's Audio Doesn't Work when connected to TV, Monitor, or AV Receiver HDMI port |
When connecting audio jack into the NUC you hear popping or clicking through your speakers | Popping sound when connecting microphone, headset or speakers to 3.5mm audio jack on NUC |
Microphone doesn't work or output is not loud enough. | NUC Microphone Doesn’t Work or Output Is Not Loud Enough |
Surround sound doesn't work in a home theater system. | Troubleshooting AV Receiver Issues on NUC |
Front panel 3.5mm audio jack isn't working. | Front Panel 3.5mm Audio Jack Does Not Work on NUC |
After system update audio no longer works | No audio output on NUC after system or driver update |
Code 28 error in Device Manager on Detection Verification under Other Devices | Seeing error code 28 in Device Manger on NUC |
If none of these suggestions resolve your issue, contact Customer Support.
Related topic |
Linux* Support for NUC |
