FAQBot
Community Manager
Community Manager
[NUC] Tested Peripherals for NUC Products
NUC products are tested with a variety of memory modules, peripheral devices and software applications. The focus of the testing is to make sure that there are no obvious issues between the NUC and devices and software.
  • The tests do not qualify the peripherals and software against NUC products.
  • Not every available peripheral or software application has been tested.
  • Inclusion on the compatibility list should not be considered an endorsement by Asus.
  • Asus makes no claims about peripherals and software that are not on the list.
Testing method
Samples of publicly available peripherals are used to see if the NUC achieves a high level of compatibility. Test descriptions and configurations vary throughout the testing, so they are not listed.
The test results provide a sample of system functionality. Changes the peripheral manufacturers make can change the operation of their products with NUC products. Asus does not retest the systems when any part of the test hardware or configuration changes (for example, drivers or firmware revisions).
Successful test results do not guarantee compatibility with other hardware. System integrators should continually verify compatibility of specific peripherals and software.
Version history
Last update:
‎10-07-2025 04:57 AM
Updated by:
