FAQBot
Community Manager
Community Manager
[NUC] System Memory Information for NUC Products NUC13RNG and NUC13SBB
Memory requirements
  • Supports two independent 1.1V, DDR5, 262-pin SDRAM SO-DIMMs with gold plated contacts. 1.2V is supported via XMP profile
  • 4000 Mhz, 4400 Mhz, 4800 Mhz, 5200 Mhz and 5600 MHz
  • Unbuffered, non-ECC
  • Single-sided or double-sided
  • Maximum memory: 64 GB
  • Minimum memory: 8 GB
  • XMP  3.0 support
  • Supports 4 Gb, 8 Gb, and 16 Gb memory technology (SDRAM Density)
See the technical product specification for your NUC for complete system memory details and requirements.
Find compatible memory modules in the Product Compatibility Tool for:
Related topic
Troubleshooting Memory Issues on NUC Products
Version history
Last update:
‎01-29-2024 06:44 PM
Updated by:
Contributors
