FAQBot
Community Manager
Community Manager
[NUC] System Memory for NUC Kits NUC7i5DN and NUC7i3DN
Memory requirements
  • Supports two 1.2V DDR4 SO-DIMMs
  • 1866 MHz and 2133 MHz
  • Unbuffered, non-ECC
  • Single-sided or double-sided
  • Minimum recommended memory: 2 GB
  • Maximum memory: 32 GB
  • Serial presence detect (SPD)
Note
Because the processor on this NUC only supports DDR4 speeds up to 2133 MHz, higher-speed SO-DIMMs operate only at the 2133 MHz memory timing:
  • DDR3/DDR3L memory modules are not supported.
  • If you plan to install just one SO-DIMM, install it in the lower memory socket.
Find compatible memory modules in the Product Compatibility Tool for:
For complete system memory details and requirements, see the technical product specification for your NUC.
Related topic
Troubleshooting Memory Issues on NUC Products
Version history
Last update:
a week ago
Updated by:
Contributors
