FAQBot
Community Manager
Community Manager
[NUC] System Memory for NUC Kits NUC7i[x]BN
Memory requirements
  • Supports two 1.2V DDR4 SO-DIMMs
  • 1866 MHz and 2133 MHz
  • Unbuffered, non-ECC
  • Single-sided or double-sided
  • Minimum recommended memory: 2 GB
  • Maximum memory: 32 GB
  • Serial presence detect (SPD)
Note
  • 2400 MHz memory modules will work on these NUCs, but because the processor only supports speeds up to 2133 MHz, higher-speed SO-DIMMs operate only at the 2133 MHz memory timing.
  • DDR3/DDR3L memory modules aren't supported.
  • If you plan to install just one SO-DIMM, install it in the lower memory socket.
See the technical product specification for your NUC for complete system memory details and requirements.
Find compatible memory modules in the Product Compatibility Tool for:
Related topic
Troubleshooting Memory Issues NUC Products
Version history
Last update:
yesterday
Updated by:
Contributors
