FAQBot
Community Manager
Community Manager
[NUC] Sporadic Connection Drops when Using Ethernet (LAN) Connection on NUC 11th - 13th Generation Products
Resolution
There is a workaround that can be done to minimize or remediate this issue: Turn off the Energy Efficient Ethernet (EEE) setting.
  1. Open Device Manager.
  2. Double-click, Ethernet Controller I226-LM
  3. Select the Advanced tab.
  4. Select, Energy Efficient Ethernet.
  5. In the Value field, select Off from the drop down.
Version history
Last update:
‎01-29-2024 06:47 PM
Updated by:
Contributors
