FAQBot
Community Manager
Community Manager
[NUC] Setting Up Speaker Systems with NUC
This article describes the steps for setting up a Home Theater PC (HTPC) system that includes an AV receiver or a sound bar.
Tips for success
  • The ports and connections on your computer, speaker system, AV receiver, and TV can differ from the examples shown. Always refer to the documentation that came with your HTPC equipment.
  • We recommend you install the latest BIOS version and graphics driver version for the NUC, available on Download Center.
  • Check your TV and AV receiver manufacturer websites to see if there are firmware updates available for them.
Hardware Required
Click to select your setup:
AV receiver, 5.1 speaker system, and television
Place the speakers
Place the speakers
Speaker abbreviations:
FL = Front Left Speaker
FR = Front Right Speaker
C = Center
SW = Subwoofer
BL = Back Left Speaker
BR = Back Right Speaker
Connect the speakers to the AV receiver
Connect the Intel NUC to the AV receiver
Connect one end of an HDMI cable to the HDMI port on the Intel NUC. Connect the other end to an HDMI IN port on the AV receiver. (A mini DisplayPort or USB Type-C to HDMI cable can also be used).
Connect Intel NUC to AV receiver
Connect the AV receiver to TV
Using another HDMI cable, connect one end of the cable from the HDMI OUT port on the AV receiver to an HDMI IN port on the television.
Connect AV receiver to TV
Select the input source
Using the television's remote control, press the Input or Source button to select the HDMI port the receiver is connected to.
Select input source
AV receiver, 7.1 speaker system, and television
Place the speakers
Speaker connection
C = Center
SW = Subwoofer
SL: Side Left Speaker
SR: Side Right Speaker
Select input source
Sound bar with just one HDMI IN port and television
Place the sound bar
Place the sound bar
SW: Subwoofer
Connect your devices
If you want to connect more than one device to it, you'll need to use an HDMI switch.
Connect your devices to a HDMI switch
Steps:
  1. Connect the Intel NUC and any other devices to INPUTS on the HDMI switch.
  2. Connect the OUTPUT on the switch to the HDMI IN port on the sound bar.
  3. Connect the HDMI OUT port to an HDMI IN port on the television.
Set the switch to the Intel NUC
Select the input source for the television
Select input source
Using the remote control for the television, press the Input or Source button to select the HDMI port the HDMI switch is connected to.
Sound bar with multiple HDMI IN ports and television
Place the sound bar
Place the sound bar
SW: Subwoofer
Connect the Intel NUC to the sound bar
Steps:
  1. Connect the Intel NUC and any other devices to HDMI IN ports on the sound bar.
  2. Connect the HDMI OUT port on the sound bar to an HDMI In port on the television.
Select input source
Using the remote control for the television, press the Input or Source button to select the HDMI port the sound bar is connected to.
Related topics
Surround sound setup guide for NUC
Version history
Last update:
‎10-07-2025 04:58 AM
Updated by:
