on
01-29-2024
06:59 PM
- edited on
10-07-2025
04:49 AM
by
ZenBot
[NUC] Regulatory Information Index for NUC Element
Click the topic for details:
| Power Adapter | BIS Certificate | NUC | |
| Model | Supplier | ||
| HKA09019047 | Huntkey | HKA09019047_BIS_Certificate Size: 638 KB Date: April 2019 | CMCR1ABA, CMCR1ABB, CMCR1ABC, CMCM2FB, CMCM2FBAV |
It can take at least seven weeks to obtain regulatory certification. Most certifications take longer, and some will take as long as six months from the time samples are provided to test houses until certificate approval.
Customers who require regulatory certification should start the process as soon as samples are available.
| Category | Details |
| EMC | Testing to ensure the device doesn't emit electromagnetic interference |
| Energy | ENERGY STAR®, ErP, and CEC |
| Power adapter | For power adapters included with NUC products |
| Radio (RF) | For products with wireless modules included |
| Safety | UL and other certifications |
The following list of regulatory test houses is compiled from an Internet search and is provided to you as a courtesy. The vendors listed don't reflect a recommendation or endorsement by ASUS. The list is provided to you as-is without warranty.
The list isn't exhaustive and there may be other vendors that better suit your needs. Since the vendors have not been vetted by ASUS, you will need to determine which is suitable for your specific regulatory needs.
| Company name | Location | Testing services provided |
| Element EMC Lab / NW EMC | List of locations | EMC, RF |
| Intertek / ETL | List of locations | EMC, Energy, RF, Safety |
| NEMKO | List of locations | Safety |
| TUV Rheinland | List of locations | EMC |
| UL | List of locations | EMC |
For details on the following trade compliance information, find your NUC on the Asus Product Specifications site. Then, select Ordering and Compliance.
Click the NUC Element product name to see the regulatory certificates, declarations, and safety information.
NUC Element
| Processor Type | NUC |
| NUC 13 Extreme Compute Element | ELM13IBi7, ELM13IBi5, ELM13IBi3, ELM13IBv7, ELM13IBv5, ELM13IBIP, ELM13IBIPE, ELM13IBi5E, ELM13IBi3E... |
| NUC 13 Extreme Compute Element | NUC13SBBi9, NUC13SBBi7, NUC13SBBi5 |
| NUC 12 Pro X and Extreme Compute Element | NUC12EDBv9, NUC12EDBv7, NUC12EDBi9, NUC12EDBi7 |
| NUC 12 Compute Element | ELM12HBv7, ELM12HBi7, ELM12HBv5, ELM12HBi5, ELM12HBi3, ELM12HBC |
| NUC 11 Compute Element | CM11EBv716W, CM11EBi716W, CM11EBv58W, CM11EBi58W, CM11EBi38W, CM11EBC4W |
| NUC 8 Compute Element | CM8I7CB,, CM8V7CB, CM8V5CB, CM8I5CB, CM8I3CB, CM8PCB, CM8CCB |
| NUC Rugged Board Element NUC Rugged Chassis Element | CMCR1ABA, CMCR1ABB, CMCR1ABC CMB1ABA, CMB1ABB, CMB1ABC |
| NUC Board Element NUC Chassis Element | CM1BB, CMA1BB CMCM2FB, CMCM2FBAV |
