FAQBot
Community Manager
Community Manager
[NUC] NUC Microphone Doesn’t Work or Output Is Not Loud Enough
Resolution
Check the microphone's boost level in sound properties:
  1. Right-click the Speaker icon on the task bar and select Recording devices.
  2. Select your microphone device and click Properties.
  3. Go to the Levels tab.
  4. Adjust the microphone boost slider to the desired level.
  5. Click OK twice to close the window.
Version history
Last update:
‎01-29-2024 07:00 PM
Updated by:
Contributors
