FAQBot
Community Manager
Community Manager
[NUC] Multiple Displays for  NUC Products NUC13RNG and NUC13SBB
This guide provides the most common multiple display configuration options for the Products NUC13RNG and NUC13SBB with 3 graphic ports:
  • One HDMI 2.1 port.
  • Two Thunderbolt™ 4 ports.
Note
  • NUC13RNGi[x] and NUC13SBBi[x] models with a "F" suffix (NUC13SBBi9F, NUC13SBBi7F, NUC13SBBi5F) don't have integrated graphics.
  • This article doesn't cover multiple display configurations for the discrete graphics card
Before You Begin
We recommend you first update your NUC to the latest BIOS and graphics driver, using Driver & Support Assistant
Click or the topic for details:
Single Display with 8K Resolution
DisplayNUC portTV/monitor portMaximum supported resolution
1Type C + Type CDisplayPort7680x4320 at 60Hz, 30 bpp
Two Displays
Two Displays (Option 1)
Two Displays Option 1
1Type CDisplayPort5120x3200 at 60Hz, 24 bpp
2HDMIHDMI4096x2304 at 60Hz, 24bpp
Two Displays (Option 2)
Two Displays Option 2
2Type CDisplayPort5120x3200 at 60Hz, 24 bpp
Three Displays
Three Displays
3HDMIHDMI4096x2304 at 60Hz, 24 bpp
Four Displays
Four Displays (Option 1)
Four Displays Option 1
1NADaisy-chain: from DisplayPort OUT on the first monitor to
the DisplayPort IN on the second monitor
2Type CDisplayPort4096x2304 at 60Hz, 24bpp
3Type CDisplayPort5120x3200 at 60Hz, 24bpp
4HDMIHDMI5120x3200 at 60Hz, 24bpp
Four Displays (Option 2)
Four Displays Option 2
34096x2304 at 60Hz, 24bpp
3NADaisy-chain: from DisplayPort OUT on the first monitor to
4Type CDisplayPort4096x2304 at 60Hz, 24bpp
Version history
Last update:
Sunday
Updated by:
Contributors
