on
01-29-2024
06:42 PM
- edited
Sunday
by
ZenBot
[NUC] Multiple Displays for NUC 12 Pro [Kit/Mini PC] NUC12WS[x][x]
This guide provides the most common multiple display configuration options for the NUC12WS with 4 graphic ports:
Note | NUC12WS models with a "Z" suffix don't have Thunderbolt™ ports. This article doesn't cover NUC12WS models with "Z" suffix. |
Before You Begin
We recommend you first update your NUC to the latest BIOS and graphics driver, using Driver & Support Assistant
Three displays. Option 1
Display | NUC port | TV/monitor port | Maximum supported resolution |
1 | Type C | DisplayPort | 5120x3200 at 60Hz, 24 bpp1 |
2 | HDMI | HDMI | 3840x2160 at 60Hz, 24 bpp1 |
3 | HDMI | HDMI | 3840x2160 at 60Hz, 24 bpp1 |
Three displays. Option 2
3 | Type C | DisplayPort | 5120x3200 at 60Hz, 24 bpp1 |
Four displays. Option 1
1 | Type C | DisplayPort | 3840x2160 at 60Hz, 24 bpp1 |
4 | Type C | DisplayPort | 3840x2160 at 60Hz, 24 bpp1 |
Four displays. Option 2
1 | Type C | DisplayPort | 3840x2160p at 60Hz, 24 bpp1 |
2 | N/A | Daisy-chain: from DisplayPort OUT on the first monitor to the DisplayPort IN on the second monitor | 3840x2160p at 60Hz, 24 bpp1 |
3 | Type C | Daisy-chain: from DisplayPort OUT on the fourth monitor to the DisplayPort IN on the third monitor | 3840x2160p at 60Hz, 24 bpp1 |
4 | N/A | DisplayPort | 3840x2160p at 60Hz, 24 bpp1 |
