FAQBot
Community Manager
Community Manager
[NUC] Multiple Display Configuration Options for NUC 9 Extreme and Pro Kits
This guide provides the most common multiple display configuration options.
NUC 9 Extreme and Pro Kits have the following:
  • One HDMI port (2.0a-compliant)
  • Two Type C ports
See the Processor Graphics subsystem section of the Technical Product Specification document for your NUC for additional information, including:
  • Multi-stream transport daisy chaining
  • DisplayPort via Type C
Before You Begin
We recommend you first update your NUC to the latest BIOS and HD Graphics driver, using the  Driver & Support Assistant
Two displays
Two displays option one
DisplayNUC portTV/monitor portMaximum supported resolution
1HDMIHDMI4096x2160 at 60Hz
2Type CDisplayPort4096x2160 at 60Hz
Or
Two displays
1Type CDisplayPort4096x2304 at 60Hz
2Type CDisplayPort4096x2304 at 60Hz
Or
Two displays option two
2N/ADaisy-chain: from DisplayPort OUT on first monitor to the DisplayPort IN on the second monitor4096x2304 at 60Hz
Daisy-chaining describes the ability to connect multiple monitors using a single connection between each one. All displays and all cables must support the DisplayPort 1.2 specification.
Three displays
Three displays
3Type CDisplayPort4096x2304 at 60Hz
Or
Three displays
3N/ADaisy-chain: from DisplayPort OUT on first monitor to the DisplayPort IN on the second monitor4096x2304 at 60Hz
NoteAdditional monitors can be available from the Discrete Graphics card. See the list of compatible Graphics cards in the  Product Compatibility Tool
Related topics
Cables and Video Adapters for NUC Display Connections
Multiple displays FAQ
How to Enable Extended Desktop Mode
Version history
Last update:
‎10-07-2025 04:46 AM
Updated by:
