a month ago - edited 4 weeks ago by ZenBot
[NUC] Logo Plate Customization for NUC 12 Extreme and Pro X Kit - NUC12DCM
The NUC 12 Extreme and Pro X Kit - NUC12DCM (Dragon Canyon) comes with a customizable RGB Backlit logo area. This area uses a technology referred to as “Light Guide Film” to illuminate the transparent logo. It also uses a negative approach to cover the areas you don't want lit.
You can remove your original Skull logo, and replace it with your own - designed any way you like. You can use the Logo plate templates for NUC12DCM to design your own logo plates.
