FAQ
Knowledge Base Articles
ASUS Router Plug-n-Share Disks Compatibility List
ASUS Router Plug-n-Share Disks Compatibility List* OS encrypted hard drives are not supported.   Wireless RouterModelFirmware versionMaximumPartitionNumberDisk Format & Maximum Partition Size:File Size:FAT32EXT2EXT3EXT4NTFS   (Read Only)NTFS   (Write...
FAQBot by Community Manager
  • 18 Views
  • 0 comments
  • 0 kudos
[Gaming NB/DT] Armoury Crate Application Introduction
[Gaming NB/DT] Armoury Crate Application Introduction Armoury Crate Introduction (Ver5.0)Armoury Crate Introduction (Ver4.0)Armoury Crate Mobile Version Introduction (Android/ iOS)Armoury Crate - Installation SOPAniMe Matrix™ Display - IntroductionKe...
  • 32 Views
  • 0 comments
  • 0 kudos
MyASUS Frequently Asked Question (FAQ)
MyASUS Frequently Asked Question (FAQ)Table of Contents [Phone] MyASUS App - Introduction  [Motherboard] MyASUS introduction  [Notebook] MyASUS-Unable to reset GPU mode to default value  [Notebook] MyASUS - Introduction  [Notebook] MyASUS- Settings  ...
  • 81 Views
  • 0 comments
  • 0 kudos
[Motherboard]How to store and load BIOS configuration files
[Motherboard]How to store and load BIOS configuration filesIf you set multiple options in BIOS and need to store or load the previous settings, you can refer to the following steps: Catalog:  1. Store BIOS configuration files to the built-in storage ...
  • 33 Views
  • 0 comments
  • 0 kudos
[Windows 11/10] How to Enable or Disable Accessibility Tool (Narrator)
[Windows 11/10] How to Enable or Disable Accessibility Tool (Narrator)Narrator is a built-in screen-reading utility in Windows that converts on-screen text into speech, assisting users in browsing websites, reading documents, and navigating applicati...
  • 28 Views
  • 0 comments
  • 0 kudos
[Mouse] Mouse Cursor Movement Issues - Sticking or Lagging
[Mouse] Mouse Cursor Movement Issues - Sticking or LaggingPlease verify the condition of the mouse feet located on the underside of the mouse. Inspect for any accumulated debris or the presence of multiple layers of adhesive feet. If any debris or ex...
  • 35 Views
  • 0 comments
  • 0 kudos
[NUC]Is it possible to extend the product warranty beyond three years?
[NUC]Is it possible to extend the product warranty beyond three years?Customers are allowed to extend the service coverage of NUC14 Essential product to match the expected length of time they like.Additionally, customer can also purchase Accidental D...
  • 40 Views
  • 0 comments
  • 0 kudos
[NUC]What’s the benefit of Intel Wi-Fi Proximity Sensing?
[NUC]What’s the benefit of Intel Wi-Fi Proximity Sensing?Intel Wi-Fi Proximity Sensing is a feature that utilizes existing Wi-Fi signals to detect a person's presence near a device, allowing the device to automatically wake up when someone approaches...
  • 32 Views
  • 0 comments
  • 0 kudos
[NUC]What happens if I use the wrong version on my NUC system?
[NUC]What happens if I use the wrong version on my NUC system?The NUC system will not function adequately because the NUC14MNK15/ NUC14MNKN25 / NUCMNK35 uses the MNTWLCPX.xxxx structure and is intended for use with the NUC14MN using the Intel® Proces...
  • 37 Views
  • 0 comments
  • 0 kudos
[NUC]Why are there different versions of the BIOS for the NUC14 Essential N150, N250, N355 and N97 and what happens if I use the wrong version on my NUC system?
[NUC]Why are there different versions of the BIOS for the NUC14 Essential N150, N250, N355 and N97 and what happens if I use the wrong version on my NUC system?The NUC14MN[x][x][x] product line has two BIOS options for the different kits/mini-pcs. Th...
  • 50 Views
  • 0 comments
  • 0 kudos
[NUC]What’s the main difference between NUC14 and NUC11 Essential
[NUC]What’s the main difference between NUC14 and NUC11 Essential NUC 11 Essential (Jasper Lake)NUC 14Essential (Twin lake & Alder lake N )8 cores Intel Core3 N355 (15W, 3.9 GHz) 4 coresIntel Pentium N6005 (10W, 3.30 GHz)Intel Processor N250 (6W, 3.8...
  • 40 Views
  • 0 comments
  • 0 kudos
Top Contributors
