FAQBot
Community Manager
Community Manager
[NUC] How to Setup Eyefinity in a 3x1 Portrait Mode with NUC Kit NUC8i7HNK
Resolution
Follow these steps to solve graphics issues on NUC Kit NUC8i7HNK:
  • Make sure all drivers are installed and are up to date. You can use Driver & Support Assistant ( DSA) to automatically search and install the latest drivers for NUCs.
  • Make sure the BIOS is up to date. Please check the BIOS Update Instructions for NUC to see different options to update the BIOS.
  • Set BIOS to defaults and test minimal components.
Follow the steps below to revert the BIOS to default values:
  1. Press F2 during boot to enter BIOS Setup.
  2. Press  F9 to set defaults.
  3. Press F10 to save and exit BIOS.
If the issue persists, contact Asus Customer Support.
Version history
Last update:
Saturday
Updated by:
Contributors
