on
01-29-2024
06:51 PM
- edited on
10-07-2025
04:58 AM
by
ZenBot
[NUC] Front Panel Header for NUC
Most, but not all, NUC motherboards have a 9-pin or 11-pin (2.0 mm pitch) front panel header. This header is on the processor/fan side of the motherboard. You can connect a power switch to this header to remotely power on or reset an NUC board that is embedded (such as in a kiosk) in a position in which the chassis' power switch isn't easily accessible.
Click or the topic for details:
Pin assignments:
| Pin | Description | In/Out | Pin | Description | In/Out |
| Hard Drive Activity LED | Power LED | ||||
| 1 | Hard disk LED pull-up to +5V | Out | 2 | Front panel green LED (5V) | Out |
| 3 | Hard disk activity LED | Out | 4 | Front panel yellow LED (5V) | Out |
| Reset Switch | On/Off Switch | ||||
| 5 | Ground | 6 | Power switch | In | |
| 7 | Reset switch | In | 8 | Ground | |
| Power | Not Connected | ||||
| 9 | Power | Out | 10 | No pin | |
Pin assignments:
| 1 | Hard disk LED pull-up to +5V | Out | 2 | Front panel LED (main color) | Out |
| 3 | Hard disk activity LED | Out | 4 | Front panel LED (alternate color) | Out |
| 9 | +5 V DC - VCC5 (1A current rating) | 10 | No pin | ||
| Standby Power | |||||
| 11 | 5 V standby - 2A current rating) | 12 | 3.3 V standby (1A current rating) | ||
