[NUC] Encountered Error: "Basic Input or Output System (BIOS) has Detected Unsuccessful POST Attempts" When USB Cables are Connected to the NUC8i7HVK
Resolution
Here are the options to resolve the issue.
- Clear CMOS battery
- Turn off the system and wait 1-5 minutes before doing the next step
- Unplug the CMOS battery wires from the onboard connector and remove the CMOS battery. Check the figure on Technical Product Specification of NUC8i7HVK on page 45.
- Wait for another 1-5 minutes
- Re-connect the CMOS battery and the CMOS battery wires to the onboard connector
- Power on the system and press F2 right away to enter BIOS
- Enable the Clear Event log
- Press F10 to save the changes in BIOS, then reboot.
- Disable the "USB" and "Thunderbolt USB Boot" in BIOS
- Turn on the system then press F2 to enter BIOS
- Go to Advanced > Boot > Boot Configuration
- Disable USB and Thunderbolt USB boot
- Enable the "Suppress Alert Message At Boot" in BIOS
