FAQBot
Community Manager
Community Manager
[NUC] Cables and Video Adapters for NUC Display Connections
The information below describes different cables and adapters that you can use to connect an I NUC to a display. For information on which cables your NUC supports, see the Technical Product Specifications for your NUC model.
Click or the topic for details:
Full-size HDMI Cables
There are multiple types of HDMI cables. Please, refer to www.hdmi.org for HDMI cable overview
Example: cable with standard HDMI connectors on both ends.
High Speed Category 2 HDMI cables
Mini-HDMI Cables
NUCs that have mini-HDMI connectors can use either of these cable types, depending on the type of port on the TV or monitor.
Example: mini-HDMI at one end and standard HDMI at the other:
Mini-DisplayPort Cables
Example: MiniDisplayPort to full-size DisplayPort:
Example: MiniDisplayPort to miniDisplayPort:
Example: MiniDisplayPort to HDMI:
Type C (Thunderbolt) Cables
Example: Standard Type C to Type C cable (connects to a Type C port on the display):
Example: Type C cable with the video adapter to a different graphics port type built right in (DisplayPort in this example).
Other Type C cables/adapters are available. Find the combination that works for your monitor or television.
VGA Cables
NUCs with a VGA port use a standard 15-pin VGA cable.
Standard 15-pin VGA cable
Video Adapters or Converters
Adapters that convert one type of graphics interface to another can allow you to connect a NUC to a monitor that doesn't have the same type of video interface. Examples:
Type C to DisplayPort
HDMI to DVI
HDMI to DVI
HDMI to VGA
HDMI to VGA
Mini-DisplayPort to HDMI
While these types of adapters usually work, they can cause graphics issues, such as:
  • No display
  • Flickering display
The best solution is a direct connection with a single cable with the appropriate connection type at each end.
Version history
Last update:
yesterday
Updated by:
Contributors
