on
01-29-2024
05:48 PM
- edited on
10-07-2025
03:43 AM
by
ZenBot
[Notebook] Troubleshooting - How to fix screen rotation problems
If your laptop is a flip series or 2-in-1 portable series, and then you experience screen rotation problems, please refer to the troubleshooting steps below.
Please go to the corresponding instruction based on the current Windows operating system on your computer:
Make sure the auto rotation is enabled in Windows settings
To enable or disable the automatic screen rotation, the laptop must be in tablet mode.
on the taskbar①, then select [Settings]
②.
If the problem persists, please continue to the next troubleshooting.
Update and confirm BIOS / Windows packages / drivers with the latest version in your PC
Updating software usually helps the system stability and optimization, so we recommend you check and often update to the latest version in your PC. Here you can learn more about:
How to update the BIOS version in Windows system
How to use EZ Flash to update the BIOS version
For executing Windows update and drivers update, here you can learn more about:
How to update drivers via customer support in MyASUS
If the problem persists after you have updated BIOS/Windows packages/drivers to the date, please continue to the next troubleshooting.
Enable and reinstall drivers in Device Manager
Restore the system from restore point
If the screen rotation problem happens recently, and if you have ever created a restore point or there is an automatic system restore existed, try to restore the computer to a point before the problem began to resolve the problem. Here you can learn more about How to use restore point to restore the system.
If the problem persists, please continue to the next chapter for troubleshooting.
If the problem persists after all troubleshooting steps are completed. Please backup your personal files, then reset the PC to back to its original configuration. Here you can learn more about: How to reset the system.
If your problem is not worked out with above solution and information, please contact ASUS customer service center for further information.
②.
