FAQBot
Community Manager
Community Manager
[Motherboard] Two-Way AI Noise Cancelation - Introduction
About Two-Way AI Noise Cancelation
Our latest audio utility leverages a massive deep-learning database to reduce background noise from the microphone* and incoming audio. Distracting keyboard clatter, mouse clicks and other ambient noises are smartly pared back so you can hear and be heard with crystal clarity while gaming or in calls.
Multiple port connection supported:
It supports all types of audio device connected, e.g, 3.5mm audio jack, USB, or Bluetooth.
How to support Two-Way AI Noise-Cancelation?
You can check the product specifications on the ASUS official website.
(Ex: ROG MAXIMUX XIII EXTREME)
Two-Way AI Noise Cancelation: Setup Guide
1.  Support List
2. Setup Guide
3.  Test Two-Way AI Noise Cancelation
1.  Support Model List
Platform
Chipset
Model
IntelZ690
ROG MAXIMUS Z690 EXTREME GLACIAL
ROG MAXIMUS Z690 FORMULA
ROG MAXIMUS Z690 APEX
ROG MAXIMUS Z690 HERO
ROG STRIX Z690-E GAMING WIFI
ROG STRIX Z690-F GAMING WIFI
ROG STRIX Z690-G GAMING WIFI
ROG STRIX Z690-A GAMING WIFI D4
ROG STRIX Z690-I GAMING WIFI
ProArt Z690-CREATOR WIFI
TUF GAMING Z690-PLUS WIFI
TUF GAMING Z690-PLUS WIFI D4
TUF GAMING Z690-PLUS D4
PRIME Z690-A
H670
TUF GAMING H670-PRO WIFI D4
B660
ROG STRIX B660-F GAMING WIFI
ROG STRIX B660-A GAMING WIFI D4
ROG STRIX B660-G GAMING WIFI
ROG STRIX B660-I GAMING WIFI
ProArt B660-CREATOR D4
TUF GAMING B660-PLUS WIFI D4
TUF GAMING B660M-PLUS WIFI
TUF GAMING B660M-PLUS WIFI D4
TUF GAMING B660M-PLUS D4
TUF GAMING B660M-E D4
Z590
ROG MAXIMUS XIII EXTREME GLACIAL
ROG MAXIMUX XIII HERO
ROG STRIX Z590-E GAMING WIFI
ROG STRIX Z590-F GAMING WIFI
ROG STRIX Z590-A GAMING WIFI
ROG STRIX Z590-I GAMING WIFI
TUF GAMING Z590-PLUS WIFI
PRIME Z590-A
H570
TUF GAMING H570-PRO WIFI
TUF GAMING H570-PRO
B560
ROG STRIX B560-A GAMING WIFI
ROG STRIX B560-F GAMING WIFI
ROG STRIX B560-G GAMING WIFI
ROG STRIX B560-I GAMING WIFI
TUF GAMING B560-PLUS WIFI
TUF GAMING B560M-PLUS WIFI
AMDX570
ROG CROSSHAIR VIII EXTREME
ROG CROSSHAIR VIII DARK HERO
ROG STRIX X570-E GAMING WIFI II
TUF GAMING X570-PRO WIFI II
TUF GAMING X570-PRO (WI-FI)
ProArt X570-CREATOR WIFI
B550
ROG STRIX B550-XE GAMING WIFI
ROG STRIX B550-E GAMING
ROG STRIX B550-F GAMING (WI-FI)
ROG STRIX B550-A GAMING
ROG STRIX B550-I GAMING
TUF GAMING B550-PLUS (WI-FI)
TUF GAMING B550M-PLUS (WI-FI)
TUF GAMING B550M-ZAKU (WI-FI)
TUF GAMING B550-PRO
B450
ROG STRIX B450-F GAMING II
TUF GAMING B450M-PRO S
TUF GAMING B450-PLUS II
TUF GAMING B450M-PRO II
TUF GAMING B450M-PLUS II
2._Setup Guide
Step 1. Open and Enter Armoury Crate
Step 2. Click “Device” and choose your motherboard.
Step 3. Click “Audio”
Step 4. Turn on Microphone input /Audio output after plugging in the audio device and select the device to which you want to apply Microphone input /Audio output
Step 5. Adjust the Microphone input /Audio output level, depending on the environment you are in.
* For the suggested Noise Type, please refer to the table below.
 LevelUser scenarioNoise Type
Low levelSlightly disturbed by the background noise during the calle.g. Keyboard typing, Mouse clicking, Fan sound, Talking sound in the office etc.
Middle level Interference caused by background noise during the call. User needs to repeat for clear conversatione.g. Sound of kids playing , Chit-chatting, Background noise in a cafe
High levelCan't hear your voice during the call. The noise has seriously interfered the call.e.g. Construction works, House renovation, Vacuuming floor, etc.
Step 6. Continue to set up for the communication or Live streaming apps.
Note:
1.        Click “Reset” when you re-plug and change audio device, or when your device is not detected.
2.        Click “OK” to continue
2._TEST Two-Way AI Noise Cancelation
To test whether unwanted background noise from your microphone or incoming audio is removed with this function turned on, we recommend to confirm by the following steps:
·            Audio output test
1.     Enable Audio Output and select your output speaker device (Ex:3.5mm->Realtek USB Audio)
2.     Open communication software (Ex:Teams,Discord,Zoom,etc.), and select output device “AI Noise-Canceling Speaker (ASUS Utility)
3.     Have one person play the background noise and speaking at the same time; while another person testing if the voice received is clear and without any environmental sound in a different spacing without any interference with the first person.
·            Microphone Input
1.     Open the audio recording app when the Microphone Input is disabled. Take Window’s Voice Recorder as example, and record your voice with your microphone. Click on the ”Record” icon to start the recording.
2.     Setup Two-Way AI Noise Cancelation in Armoury Crate (Please refer to the Instruction above).
3.     Setup Two-Way AI Noise Canceling Microphone(ASUS Utility) in the Sound Settings of Windows.(Please refer to Instruction below)
Step 1. Click “Open Sound Settings”
Step 2. Select “AI Noise Canceling (ASUS Utility) in Input
4. Open the audio recording app again and record your voice with your microphone. You can compare the difference to check whether Audio Output is enabled.
Version history
Last update:
‎10-07-2025 04:08 AM
Updated by:
