on 01-29-2024 05:22 PM
[Motherboard] Installation and Frequently Asked Question(FAQ)
Common problems about ASUS New Motherboards, including parts Installation, frequently Asked Question(FAQ), you can refer to the following lists :
How to confirm the motherboard model, you can refer to : [Motherboard] How to check the model name?
Instructions:
For the installation of each parts in the computer, such as CPU, CPU cooler, memory, hard disk, graphics card and other PCIe devices, please refer to the user manual of the corresponding motherboard model in ASUS official website.
1. First, please search and download the user manual of your motherboard model from ASUS Download Center. Enter your motherboard model in the search box on the left, click on the corresponding model in the model list prompted below, and then select "Manuals and Documents" on the right. Refer to the image below:
(ROG MAXIMUS Z690 FORMULA for example)
2. Taking ROG MAXIMUS Z690 FORMULA as an example, the screenshots of the English manual are as following. According to the catalog and search function, it is relatively easy to obtain the required information (mainly refer to Section 2.1)
