[Lyra][Application] How do I check the connection quality between Lyra nodes?
The Lyra system will automatically find the best route of connection between nodes. The amount and color of the line shown on the Network Map indicates the current connection quality.
- 3 green lines: Indicates the connection quality between nodes is great.
- 2 green/yellow lines: Indicates the connection quality between nodes is still good.
- 1 yellow line: Indicates the connection quality between nodes is fair, but it would be better to move the 2 nodes at the ends of the yellow line closer to each other.
