FAQBot
Community Manager
Community Manager
[LCD Monitor] MB16AMT Android phone and function description
[LCM] MB16AMT- My Android phone camera doesn't work when connecting with MB16AMT
Camera may not work for some Android phones when ”Force Rotate” function from Handy Touch is activated, please deactivate the ”Force Rotate” and the camera will work properly.
[LCD Monitor] MB16AMT- Why doesn't the display work when I connect with my Android phone?
Before connecting the LCD monitor with your Android phone, please install the “ZenScreen Touch” app and the “DisplayLink Presenter” app first from ASUS website or Google Play Store.
When connecting with your Android phone, messages will pop up asking for connection permissions for the above two apps.
We strongly recommend you choose “Never Show Again” and press “OK”. When the app shows “DisplayLink Presenter will start capturing everything that’s displayed on your screen”, choose “Start now”.
If you don’t choose the correct options, please reconnect the MB16AMT to your phone and then try again.
[LCM] MB16AMT- Why does screen image freeze or stop working after connecting with Android phone?
This situation could happen due to the phone system settings.
  •  If you connect with a Huawei smart phone, please follow the process below to adjust the phone system settings:
Settings -> Battery -> App launch -> Find ZenScreen Touch & DisplayLink -> Change to “Manage manually” -> Press “OK” -> Re-connect your Huawei phone
  •  If you connect with Vivo/OPPO/Sony smart phone, please make sure the “OTG” option or “USB detection” is activated.
[LCM] MB16AMT- Why didn't the touch screen work when connecting with my Android phone?
For MB16AMT device, the touch feature is only available if your Android phone offers/supports HID multi-touch. Please confirm with your phone manufacturer to ensure its function availability.
Version history
Last update:
Sunday
Updated by:
Contributors
