FAQBot
Community Manager
Community Manager
[LCD Monitor] How to Clean LCD/OLED Panel/Monitor
Cleaning LCD/OLED panels (including sensors) requires special attention and care to avoid damaging the screen. Here are some safe and effective cleaning methods:
Materials Needed:
Microfiber cloth: A soft cloth that will not scratch the screen.
Purified water: Avoid using water containing minerals.
Spray bottle: Used to spray cleaning fluid onto the microfiber cloth, rather than directly onto the screen.
Cleaning Steps:
Turn off the device: Before cleaning, ensure the device is turned off and unplugged to avoid short circuits or other risks.
Dry cloth cleaning: Use a clean microfiber cloth to gently wipe the screen surface to remove dust and loose particles.
Damp cloth cleaning: Spray a small amount of purified water onto the microfiber cloth (do not spray directly onto the screen/sensor), and gently wipe the screen surface, avoiding excessive force.
Dry the screen: Use a clean microfiber cloth to gently dry the screen surface, ensuring no liquid residue remains.
Precautions:
Avoid using alcohol or ammonia-based cleaners: These chemicals may damage the screen's coating.
Be careful not to spray liquid directly onto the screen: Liquid may seep into the edges of the screen, causing damage to internal components.
Avoid excessive force: Excessive force may damage the screen or leave scratches.
By following the above methods, you can safely and effectively clean LCD/OLED panels (including sensors) to maintain a clear and undamaged screen.
Version history
Last update:
‎10-07-2025 03:50 AM
Updated by:
