FAQBot
Community Manager
Community Manager
[LCD Monitor]How to adjust the frequency and resolution of the monitor?
To provide you more detailed instruction, you can also click ASUS Youtube video link below to know more about How to adjust the frequency and resolution of the monitor
https://www.youtube.com/watch?v=zyySMlQgPmY
Please follow the steps as below:
(The below example is Win 7)
1. In the Control Panel (Press the Win+R keys to open Run, type Control, click/tap on OK) -> Appearance and Personalization -> Display -> Screen Resolution, here can adjust the resolution; then click Advanced settings to confirm screen frequency.
2. Switch to the page of Monitor; you can know about the Screen refresh rate.
(The below example is Win 10)
1. Click on the right button of your mouse on an icon of Desktop-> display settings -> Display -> Resolution, here can adjust the resolution
3. If you can't adjust the resolution and refresh rate that you want, please check the Supported Timing List on the user manual of this model. If the monitor can’t reach to the supported timing spec, please contact ASUS Service Center.
For example VP278 Support Timing List
Please refer to the user manual.
Note: "The screen resolution and refresh rate vary depending on the computer's hardware specifications and display output."
4. If the display resolution or refresh rate problem still cannot be problem?
Please refer to FAQ: [LCD Monitor]The monitor cannot display the correct resolution or displays abnormally or flickers. Y...
Version history
Last update:
‎10-07-2025 03:44 AM
Updated by:
